I am trying to get my iPhone to connect to my PC via RealVNC over the internet. I can get it to connect no problem locally, just not over the net. I read some other threads and they got me further than when I started, but I am not there yet. My biggest problem may be that I am behind two router firewalls (my switch would not work with Verizon's router, so I used my old router as a switch to create more connections). So here is where I am at:
iPhone running MochaVNC Lite
PC running RealVNC Free v.4.1.2
1st router at address 192.168.1.1
2nd router at WAN 192.168.1.3
2nd router at LAN 192.168.0.1
PC at 192.168.0.21
RealVNC set to port 13xxx
My IP is dynamic, but it stays the same for weeks or months (long enough for me to get this figured out anyway)
So, to start, I forwarded port 13xxx on the first router to 192.168.1.3 (the second router). Then I forwarded port 13xxx on the second router to 192.168.1.21 (my PC). Before I did all of this, VNC on my phone would immediately say I cannot connect. After setting it up this way, my phone viewer says it is attempting to connect to my external IP, but eventually fails. So, it seems like I am on the right track, but I am just missing something.
I like to get this figured out using my current hardware configuration if possible. If need be, I can try moving my PC onto the first router if it would help.
Any help would be appreciated.
PC at 192.168.0.21
