rhansen5_99
- Nov 12, 2001
Hey guys I am running into a bit of a snag and was wondering if you guys have any suggestions. Basically I am trying to migrate some vms from VMWare Workstation 9 on a local server to a ESX server in a Colo facility. I am trying to use Vcenter Converter but I think that the VPN connection between the two locations is timing out causing the conversion to fail. The VM's are about 80gb and the speed is around 1.5mb/s of the transfer.
I do have access to the datastore and copy the vkmd and vmx files directly but we attempting this I get a incompatible version warning or something of that nature. Is there a way to get the converter to create the proper kind of file without connecting to the infrastructure? Or possibly a freeware tool to help out?
Thanks a bunch.
Thanks a bunch.
