If you are using vCenter Server Standard (latest version) and ESXi Enterprise Plus (latest version) is it possible to setup SRM in a multi-tenant environment?
I know with VMware Replication you need to use the same vCenter versions. Found out when trying to setup a 5.5 environment to a 5.1 environment.
But even if your datacenter was running the same version of vCenter and ESXi that your customers are using in their datacenters, is there any real way to set it up for multiple tenants?
