aaronearles
- Aug 31, 2006
Cross posted this in the virt section, looking to get opinions from the two different groups here, so hopefully that's not a big deal...
Okay, so I'm putting together a whitebox for ESXi, I have a perc5/i and 6x 1TB 7200 SATA drives, the plan was to put them in RAID10 because I'm not real concerned about capacity, just decent performance. I don't have a specific application in mind, it will mostly be used for windows labs and testing software, nothing intensive but I'd still like to configure it for best performance, and I plan to house my fileserver there too just as a crao datastore but I would like it to be redundant.
So, because I'm leaning more toward performance, not capacity, I was thinking raid10 because of the small writes each os will be making to the drive - figuring parity calculations will slow things down with lots of small writes. Is the performance difference significant enough to give up 2TB on the array, or would you recomment RAID5 instead?
Also, any suggestion on stripe size? OS writes are going to be mostly small stuff, but the vmdks are going to be quite large, but I'm not sure if that matters...
Thanks guys!
Thanks guys!
