romeoagogo
- Aug 25, 2004
Hi, I want to setup an older PC I have (XP 2400+, 1gig PC2700) as a server type box for all my media. I want to run ubuntu on it because its easy to setup and offers more options for server-y things later. My big problem however is that I also want this server to be able to stream movies to my xbox360. The only way I can see doing that is by using WinXP on VMWare and wmp11 to stream. So my questions are these -
1) Will encoding performance suffer using a VM? I encode all my videoa to WMV once they are downloaded using WMEncoder 9 and then stream them with WMP11.
2) Is file access between Ubuntu and the XP VM easy? Meaning can I setup a partition for all my media files and access them from both Ubuntu and the VM?
3) Will the VM be able to stream content without any hiccups? Will it maintain a decent speed?
4) Do you think this will work and is worth doing to keep my "server" running linux?
Thanks
Thanks
