I am extremely interested in VMware NSX and SDN but what I would like to know is does anyone have any solid experience with using it in production? I'm not talking about a slice of its components but I am talking a full scale NSX SDN deployment, DLR, DFW, ESG, Controllers - the full works.
Questions:
1. How easy was it to design and migrate to, what did you use as an aid for the design piece because there is not a lot of material out there yet.
2. How stable is it and have you had any caveats?
3. Software API / SDK, are you using it? I see on the VMware Blogs the article around automating firewall rules based on un-authorized putty connection attempts, the options for this seem huge.
4. What are your overall thoughts on the product? the good and the bad and would you deploy it over again if you had the choice.
I can't help but think this is extremely exciting times for both network and virtualisation based careers, SDN is surely now ready to explode on the market with some serious uptake.
Anyway appreciate your thoughts and NetJunkie if you read this, thank you for the Pluralsight courses, extremely good - when will you be adding more? any more in the works? what is your experience with "production grade" NSX? would really appreciate your thoughts.
Thanks
Questions:
Thanks
