StarTrek4U
- Jan 8, 2003
So I have a pretty basic VM setup at work, a VCenter Server with 3 ESX hosts in an HA config. All are running ESX 4. So here's my issue/question....
I've updated my VCenter Server to the most recent version, and was working through patching the hosts. So I put the first host in maintenance mode, apply the patches, etc... all goes fine. It reboots, then I reconnect it to the HA cluster. That's when the fun begins. It will add to the cluster and do the config fine and join ok, but only for a few minutes before it shows disconnected in the VSphere client. I can connect to it directly fine, all the VMs on it power up fine, etc. It just won't stay in the cluster, if I restart the vCenter Service on the VC Server it will show up fine again but then disconnect after a few minutes.
My guess is that all the hosts need to be on the same version of ESX, especially since I'm quite a ways out for patches (going from build 208167 to 261974), but I wanted to confirm before I apply the patches to my other two hosts then break HA completely.
Any insight is appreciated.
