vmWare Fusion 2 Question
prodigee
How do you adjust the disk size in VMware Fusion? Because it seems to be locked at 40 gb and I want it more around 10 gb.
Thanks,
prodigee
When you create a VM just do "Customize" on the settings page...then go in and set the HD to whatever you want.
But when I do that, it just gives me a place to save and thats it...
Save it..then at the end it'll popup the settings page where you can customize hardware. From there click the Hard Drive one and change the size. Do this before building the VM.
