VMWare Diskless time problem
ojmalik
Did a quick search and couldnt find any answers anywhere.
I'm having a problem where the times in fahlog are incorrect. Both fahspy and fahmon get confused by this and can't calculate ppd correctly. here's a snip from one of the log files:
[18:29:51] Timered checkpoint triggered.
[18:29:51] Writing local files
[18:29:51] Completed 240000 out of 500000 steps (48 percent)
[18:29:51] Completed 245000 out of 500000 steps (49 percent)
[18:29:51] Completed 250000 out of 500000 steps (50 percent)
[18:29:51] Completed 255000 out of 500000 steps (51 percent)
[19:44:48] Timered checkpoint triggered.
[19:44:48] Writing local files
[19:44:48] Completed 260000 out of 500000 steps (52 percent)
[19:44:48] Completed 265000 out of 500000 steps (53 percent)
[19:44:48] Completed 270000 out of 500000 steps (54 percent)
[19:44:48] Completed 275000 out of 500000 steps (55 percent)
[20:58:37] Timered checkpoint triggered.
[20:58:37] Writing local files
[20:58:37] Completed 280000 out of 500000 steps (56 percent)
[20:58:37] Completed 285000 out of 500000 steps (57 percent)
[20:58:37] Completed 290000 out of 500000 steps (58 percent)
[20:58:37] Completed 295000 out of 500000 steps (59 percent)
For some reason the time in the VM isnt progressing as it should. Has anyone seen this before?
I have the machines set to idle priority when uncaptured, but it does it even if i have them at normal priority. I am using VMWare workstation with notfred's folding cd, no backup. I'm thinking about letting them finish, then trying vmware server instead, but just wanted to see if anyone else had run into this in the meantime.
this is a q6600 @ 3.2ghz, 2 gigs memory, xpsp3
Thanks for any insight. I'm trying to bring up as many machines as i can for [H]ardApe
got another q6600 and e8400 left to bring up after this.
Do you have VMWare tools installed ?
If not then extract and install them, as I've found they fixed the time stamp for me.
Other than that just set the client to ignore deadlines.
That way if the clock jumps a lot forward at any point, you dont loose any work.
Luck ............ :D
I've had that happen, because of the load on the system and the VM, it doesn't keep the time synced properly. It will show the wrong time... I just let it go myself.. I never missed any deadlines or anything...
I never found a way to fix the issue tho...
as far as VMware tools go... I don't think you can install them with the diskless client.. atleast I never could.
VMWare server will not fix the problem for you. I have the same problem on one of my systems. I'm not 100% sure what causes it but in my case I think it was because I moved the VM images from another system. When on the previous system the time was usually right on. Now, the time in the VMs runs rather fast. I made a change or two to one of the VMWare files and managed to slow the clock down some, but it still runs fast.
There is no fix from VMWare for this issue. There's a workaround or two like what I did but they aren't perfect. I'm at work right now and can't do a search for the adjustment but it has to do with something in the one of the VM image files in regards to the clockspeed of the processor. The way VMWare keeps time is based on the clockspeed of the processor.
If I have a chance tonight, I'll see about digging up the info for making the adjustment to possibly get the time close. It's still a good idea to make the change to the client to ignore deadlines.
