Hi,
I'm getting in trouble with vmotion at 10%.The success percent is about 67%.The environment is : One vcenter server,two ESX server with HA, three cisco 2960 switchs.
Vcenter connected switch A, which connected switch B and switch C,all of these ports belong to vlan 2. There are two ESX server ,each server have four Nic ports.Two ports are service console ,which belong to vlan 2,and connected switch B and switch C. The other two ports are vmkernel ports,which belong to vlan 3, and connected switch B and switch C.All of these ports on switch are access mode.Only the two ports which connected Swtich B and switch C are trunk mode.
The vmotion success percent is about 67%, I have checked vmkping on ESX server and both of them are ok. And there are no error logs on ESX vmkernel log when vmotion failed.
But when I disconnect cabel between the switch A and switch C , or switch A and switch B,meaning one way.The success percent grows to 90% percent.
I have searched it at Vmware website, the answer is bollow:
http://www.vmwarewolf.com/vmotion-fails-at-10-percent/
And I have check all of these situation,but I didn't get any result.
I have no idea about it.Is there any special configuration on switch?
