I recently pruchased a professionally Vmodded Built By ATI 9800 Pro from a user on this forum. (thread)
Transaction went off without a hitch, everything happenned exactly like it should.
Except that the card appears to be broken. I'm not accusing anyone or anything; I have no reason to believe Jared has anything but good intentions.
We wanted to see what the [H] had to say about the issue.
The story:
Fedex dropped off the package today. I came home and opened it, it was well packed, took the card out of the box, and plugged it into my PC. I connected the two fan plugs and the power plug for the card, and connected the rheostat to the big GPU heatsink.
Power on. No video. No beeping. My IC7-Max3 acted like it was going to POST; I use the FanEQ feature, and the CPU fan slowed down to the speed I set, but other than that the system never gave any indication that it was even sort of working.
I tried the standard approaches to troubleshooting: remove all other peripherals and cards, reset CMOS, played musical molexes with the fans and card power plug... nothing. Same thing every time.
I tried it in two other computers with the same result.
Systems I've tried this in (all at stock clock and voltages):
IC7-Max3 / P4 2.4C / Antec 350W PSU
IC7-Max3 / P4 2.8C / Enermax 350W PSU
Dell i850 mobo / P4 1.5A / Dell PSU
All producing the exact same situation. All these combinations normally work perfectly, under load from multiple HDDs and opticals, with the two IC7s overclocked to 3.2GHz+.
The only thing I can't really try is a higher powered PSU, although without any other peripherals and at stock settings other than the card, I don't see a name-brand 350W PSU being and issue.
Thoughts? Comments? Flames? Please, share...
edit: clarifications
The story:
