vm-gpu question
84gthatch
I might be stupid(likely) but i finally decided to play with stuff to get a couple of the vm/notfred vm's up however when i do on my amd i'm getting severe choking of the gpu clients how do i fix that? is that where the affinity thingie comes into play?
Yes, that is where WinAFC would come in handy. You would set the GPUs to high priority and the VMs to Below Normal or Idle priority. I've got the settings you'll need in some of the current threads
