VM Cooling Query
jkrib
My VM Campus Edition was delivered in mid - Oct. I love the machine - the attention to detail is amazing. However, from the outset, my AC freezer 7 has been disinclined to spool up (300 - 500rpm max bios reading) in the face of escalating core temp readings - resulting in temps that are somewhat high, but not necessarily alarming under 100% load in Intel TAT (39-41degC idle; 65-70degC 100% load).
VM (most especially Ms. Taylor) have made Herculean efforts in an attempt to rectify this seeming anomaly. Freezer 7 and DP965LT MB both replaced on site, ultimately the machine was returned to Richmond for repair.
Upon its return, the machine looks beautiful, temps are down slightly. But the CPU fan anomaly still persists. Even under TAT full load, Freezer 7 speed never surpasses ~500 rpm.
Although I am admittedly a novice, alteration of any or all settings in intel's most current BIOS will stop this throttling. Noise is not a real concern for me. I would prefer the fan operate constantly in the 2000rpm range (as VM's tech support indicated their mule's Freezer 7's typically do).
Any thoughts?
Any thoughts?
I can give you a workaround solution that was acceptable to me.
VM replaced my freezer 7 as well. The fan does speed up but only when it reaches an unacceptably high temp over 60 degrees C. I updated the MB bios as well.
My solution; simply plug the fan into one of the three pin connectors vs the 4 pin( w speed control) which will run it at around 2000rpm. Using TAT, my idle temp is around 37 C and around 53 C under load (using TAT load set 100% on both CPU's.) Why VM did not suggest this is a bit odd. :confused:
I think the fan is reasonably quiet even at full speed.
Thanks for your help! I'll make the fix ASAP.
