Network Layout is like that...
except the red part does not exist -- it is my goal.
I want it to replace the green box on the right side (Training Center).
I'm stuck on how to actually go about doing this:
As far as I know
1. enable two VLANs on the port that is connecting training center and core switch. make that port 101 and 102 using 802.1q VLAN Tagging right?
2. do the same for the downstairs/training center setup
3. do the normal stuff
a. setup DHCP helpers on core switch
b. setup DHCP stuff on the actual DHCP server
c. setup the SSID's with the proper security
I've added simple VLAN's before by adding switches to the network and then do the normal add a vlan/setup helpers/ get it going process, but I have never gone to the point of putting two vlans in one area, and then trying to route the data back up to the other parts of the network.
I know it is possible, I'm just not 100% sure on how to implement it. Am I right in saying I will need to setup VLAN Tagging?
FYI:
Training Center - HP ProCurve
Core - Foundry SuperX
Secondary - Foundry FastIron
I'll be constantly checking this post if anyone has any suggestions.
If HardForum is the wrong place for this type of question, anywhere else where I might find some good advice?
