I am trying to put my grasp around Port Based VLAN. The way I am thinking about it is as followed:
16 port switch
Port 1 is plugged into the gateway - 192.168.1.1 which hands out DHCP 192.168.1.100 to 200
I create VLAN2 - Port 1 is in it, and Port 2 through 8 are in it
I create VLAN3 - Port 1 is in it, Port 9 through 16 are in it
So computers plugged into VLAN2 should get IP in that range as should VLAN3 but computers in VLAN2 shouldn't be able to get access to VLAN3 computers (ping, files, etc). Correct?
How exactly do I set this up with a Dell Powerconnect 27xx series (I have a 2716 I am messing with in the office)? It by defaults have VLAN1 that you cannot modify. I tried this 2 ways.
I created VLAN2, Tagged Port 1, and Untagged Port 2-9.
I created VLAN3, Tagged Port 1, and Untagged Port 10-16
Plugged machines in, one machine in VLAN2 got a 192.168.1.179 ip. one machine in VLAN3 got a 192.168.1.199 IP. I could ping each from any side.
I then did same thing VLAN2 - Tagged Port 1 through 9, Vlan3 - Tagged Port 1 and 10-16. Same issue.
What am I doing wrong?
Thanks,
Dan
16 port switch
Thanks,
Dan
