Vizio VO37LF - expecting too much?
LanceDiamond
I just got this unit at Costco yesterday:
http://www.vizio.com/productDetails.aspx?id=2640&pid=1506
It's a 37 1080p set with 3 HDMI inputs, 1 VGA and several component inputs.
First thing I did upon bringing it home was hook it up to the PC in my sig (the 8800GTX one.) I previously had a Dell 2405 FPW and a Westinghouse LVM37-W2 on the 8800GTX card. The Westinghouse always looked great attached via the VGA cable, it never looked right attached via HDMI so I tried the Vizio via VGA first. I've since tried the Vizio via HDMI and even attached to my laptop via VGA - all with the same results I describe here.
I happen to have what is I guess a weird color combination on a webpage of mine. It's fairly dark green with fairly dark red - and I noticed a crawl along the intersection of *some* these colors on the Vizio. It seems to depend on where on the display the line is, with middle of the display being the worst. I played around some and created this image:
This is just a somewhat bright green background with some thin red lines across it. On the Vizio, the horizontal lines have a shadow above them and a slight crawl mid-line. The diagonal line has a rope looking pattern alternating above and below it from end to end.
HDTV content from HDNet Movies looks great - most PC images look pretty good but this crawl/shadow issue is bugging me more and more.
Am I expecting too much of a 37in TV when I think it should have a basically flawless PC picture? VERY interested in any Westinghouse LVM37-W3 owners looking at the image I created and telling me if they see a green background with a few lines and nothing else.
Thanks!
I can only see the rope looking pattern on the diagonal line.
On a side note, how are the blacks and color?
Also, is it glossy?
Blacks and color are good - video/movies look great. I am going to take it back and swap it for another of the same model, I think there is something wrong. And even with something wrong, it looks good with video/movies.
Not glossy and bezel looks better than Vizios I've seen in the past (bezel is all black rather than black/silver.)
So on the horizontal lines in that image, you see no shadows above the lines? The rope pattern may be jpeg induced since I saved it as a jpeg.
What are you looking at the test image on?
if the input is worth it to you, I have a vx24L i bought last summer. the image you posted appears to have bad artifacting though.
if you're interested in my results w/ my vizio, do you think you could repost in a higher quality? i'm kinda interested myself :D
I have a VU42LF. I had to set DNR to Strong and Sharpness to 4 to get decent PC text quality with no shadowing or halo around it. Try playing with those settings. Also, my set came with the backlight set to 90%, which made everything look like complete ass.
Ok I've learned a few things...
1) Don't ever save an image you're trying to use as an objective quality test in JPEG format - this was stupid - JPEG introduced a LOT of the artifacting in that image - maybe all of it.
2) I'm not real confident in Costco Concierge tech support people. I just called and the guy swore to me that the ONLY way to have any 1080p TV display a non-interlaced image was to feed it a Blu-Ray signal - the computer image is interlaced. WTF? (103% sure this is wrong.)
3) The adjustments on the TV make a big difference and but don't quite make the image perfect. Much closer now - if a friend comes over and tells me I'm crazy, it looks fine I may NOT go exchange this unit.
Key adjustments for computer use:
Advanced Adaptive Luma
This setting seems to introduce varying degrees of dot crawl in the actual screen shot I have linked - saved as a .TIF this time.
This setting is also just pure evil if you're not aware of what it's doing and you think something is wrong. It seems to dynamically mess with the overall brightness of the picture based on what is being displayed. So for instance if you're displaying a computer image and you go to a light background web page it'll get super bright. Go to a dark background page and it may fade thinking it's trying to help the image display properly or something. It led me to think either I was seeing things or the monitor had some kind of serious electrical problem because it would never stay at the same brightness level.
Color Temperatue
Changing this affects dot crawl and flashing on images with some high contrast border areas. Warm or Normal look ok, the rest look bad to awful.
Noise Reduction
In my case, I can't see any difference regardless of what I set this to. I trust it made a difference in the other poster's case so I set it to Strong as he suggested.
Sharpness
Anything above 3-4 here introduces halo/shadows around high contrast areas of the image I've linked here.​
Here is a partial screen shot of the web page that I noticed problems on:
http://www.manofleisure.com/valid-test-yahoo.tif
(might want to right click and save target as)
The problem areas are the thin dark border lines around the weather/mail/etc in the Personal Assistant area. Based on the settings, those lines crawl a little or a lot or flash slightly. Current status: Flashing slightly, no crawl.
In the test image, the news category areas on the left side (Business News, Slashdot, etc) at the bottom of each section where the green box meets the dark red background, there can be a halo/flash/crawl. Current status: Flashing slightly, no crawl.
My current settings:
Picture Mode: Custom
Backlight: 50
Brightness: 44
Contrast: 50
Color: 50
Tint: 0
Sharpness: 3
Noise Reduction:Strong
Color Enhancement: Off
Advanced Adaptive Luma: Off
Enhance Contrast Ratio: Off
Color Temperature: Warm
Red/Green/Blue: 128
If I do wind up getting another one, at least I can come back to this thread to find my settings now. :D
Just to end this saga...
After playing with the settings mentioned in my post above, having a friend look at it and playing around in NVidia control panel, this monitor actually looks great now.
The key was that there are so many settings on the monitor itself that can introduce pretty bad image problems. If you are changing just one setting at a time you might have a hard time finding the combination where all the problem settings are in their "right" configuration. Thanks to the other poster here for getting me on that track!
Very happy with the Vizio now. :)
Glad it worked out. Returning it would have been easy though with Costco
Glad to see it all worked out too. I had a few minor image issues when I first got my Vizio SV420XVT and it took a little while to figure out that it was all settings stuff, but I calle d the Vizio support and they were really helpful in recommending settings. Also, google settings and you can always find other people who have played around too. After that was taken care of the picture quality and everything else has been perfect.
Damnit.
Been using the monitor since my first post - finally have all the mounting stuff show up and ask someone to come help mount it tonight. Sit down at it just now, having used it earlier today and....
I have a dark horizontal line slightly below the mid-point from top to bottom - shows up across all inputs, with or without a signal. Lighter on the edges and dark in the middle.
I've powered off several times, reset the factory settings and readjusted the picture which still looks fine, aside from this line.
Going to Costco to swap it for another identical one, minus the line. I guess it could have done this tomorrow, after I get it mounted.
Went to Costco, swapped Vizio for a new one.
Pros: Costco staff friendly, swap went with no problems, new Vizio looks great once adjusted
Cons: Both people @ Costco that helped with the swap had personally experienced a Vizio with a line which they resolved by swapping it out. :confused:
I won't be mounting it on the wall just yet - I'll use it for a while, make sure no line shows up and then mount it. The fact that the other one took two weeks to show up ... well if I have to take it down off the wall, I'll be refunding it assumning it's within 90 days.
I just called and the guy swore to me that the ONLY way to have any 1080p TV display a non-interlaced image was to feed it a Blu-Ray signal - the computer image is interlaced. WTF? 103% sure this is wrong.
I'll double it - 206% sure thats wrong.
Feeding 1920x1080 via DVI or HDMI is a progressive signal. Tech is a moron.
