I am having troubles getting the dual boot to work again. I landed a copy a Vista Ultimate and a 400 gig hard drive over the weeked. So what I did was disconnect my Raptor from the motherboard and connected the 400gig hard drive to it. Then I installed XP Pro on the 400 gig hard drive. Once that completed, I reconnected the Raptor to the motherboard and formatted and installed Vista Ultimate on it.
I thought that if you install Vista after XP, the Vista bootloader should automatically detect an XP and add it to the bootloader? Well it didnt, and it just boots automatically to Vista. So I been trying to edit the bootloader through BCDEDIT and having no luck. How would I go about getting it to boot properly? Under Vista, Vista is on the C: drive and XP is on the D: drive.
