Vista x64 - Task Manager question.
ShePearl
In Windows XP, task manager showed "Peak" memory usage under Commit Charge section. However, in Vista, I can't seem to find anything showing peak memory usage. Is there any way I can see what peak memory usage is?
I thought there were many Vista users in this forum. None of those know how to view peak commit charge??
From here:
If you are an advanced user, you might want to view other advanced memory values on the Processes tab. To do so, click View, click Select Columns, and then select a memory value:
•Memory - Working Set. Amount of memory in the private working set plus the amount of memory the process is using that can be shared by other processes.
•Memory - Peak Working Set. Maximum amount of working set memory used by the process.
•Memory - Working Set Delta. Amount of change in working set memory used by the process.
•Memory - Commit Size. Amount of virtual memory that is reserved for use by a process.
•Memory - Paged Pool. Amount of committed virtual memory for a process that can be written to another storage medium, such as the hard disk.
•Memory - Non-paged Pool. Amount of committed virtual memory for a process that cannot be written to another storage medium.
Thanks for the input guys.
Hmm.. I was looking for a way to view total peak commit charge rather than those for individual processes. (Just like the way XP showed in Commit Charge section of task manager). This way, for example, I can see what total peak memory usage was after I finish a game.
