This is a newly built computer and I am having problems running 4gb of memory.
I did a clean install (obviously) of vista on a hard drive with only 1gb of memory in.
After installation and vista boots up fine and dandy everything seems to work fine. I then put 2 more sticks of memory in for a total of 3gb and everything runs fine. I run tests and everything checks okay.
Now when i put my 4th stick in when windows boots up its giving me this windows boot manager error and says to run repair off the vista disc. Problem is when i try to boot from disc it gives me the same error. Something like the one file is corrupt insert disc to run repair (which I cant).
If I take any one of the sticks out, vista boots up fine.
Has anyone experienced this problem before? And is there anything i can do to fix this?
