Vista X64 boot problems
NukeULater
Hello everyone, I am having some problems with my Vista ultimate X64 setup. Last night it crashed and I could not get to to boot back up. I ended up having to reset my motherboard's BIOS. This allowed me to boot into safe mode, which is always a good sign but that is when that ended.
The crash must have corrupted my video card driver. So I uninstalled it rebooted and it worked perfectly in non-safe mode windows. I installed the latest nvidia drivers and rebooted. It went well until just after the loading bar, then the screen went black and the computer stopped accessing the hard drives. I can't figure out what to do if I cannot get the thing to boot with the drivers installed. :confused:
Specs are in my sig. Any help would be appreciated.
How many monitors/TVs do you have connected to your vga?
Uninstall the vga drives in safe mode and install OLD vga drivers. See if it helps.
I just tried that, nothing changed. I was using nvidia's 178 drivers to test.
Once again it got to the loading screen the hard drives working away, then a black screen and just after the hard drives stop reading but the PC is still on. I will say that way until I turn it off.
It's really weird that you had to reset BIOS to get it going. Try to unhook all storage HDDs and boot only with a main drive.
I figured out what it was. One of my 8600GT's died. When I remove that card I boots into windows no problem. If I take out the good card, I get the exact same BIOS error.
Thank you so much for your help hmz, it is greatly appreciated. :)
