SuperSubZero
- Nov 21, 2000
If you absolutely have to staple your hand to a workstation that is old, you might as well be running NT4 on it. NT4 will handle old hardware better than even Win2k.
Steel Chicken said:upgrading from any of the 9X/me to XP or 2K = the win
upgrading from 2k to XP, not worth it for most users
uprading from XP to vista...I dunno...whats in there we really need? more cpu exploding and GPU retarding eye candy?
GeForceX said:Well, for some reason djnes/Phoenix keeps touting XP for how great it is. Perhaps they find use in XP's deep configuration for their admin work that 2000 was lacking. After all, MS gets most of their feedback from IT pro's, not the newbies that live on a farm.
-J.
or the standard was developed after the OS... Security is fast moving.Steel Chicken said:3rd party apps shouldn't have too. some of the firewalls do, because of the way windows looks at security as an afterthought.
Did you not read what I posted before? Here's I'll try again.Steel Chicken said:upgrading from any of the 9X/me to XP or 2K = the win
That's why you are really concerned with? Older machines???Steel Chicken said:thats just memory. try running both of those OS's (2K + XP with classic look) on an progressively older machines. which one will continue to run on older hardware, and which one will choke first?
Vista will be more secure, more configurable, it will support new technologies that Win2K and XP do not, and it will have substantially more than "a handful" of new features. I think that makes it a better OS.Steel Chicken said:Doesn't change the fact that releasing a new OS all the time with a bunch of new eye candy and a handful features fails to make it a better OS.
The *only* reason we're having this discussion is because MS has retrofitted so much new code and technology onto XP and Win2K. That obviously makes the ugprade picture much less clear, simply because you're already getting much of what's in Vista for free. Much...but not nearly all of it.But us techie types should know that something is either worth the money to upgrade, or isn't.
Spetsnaz Op said:LOL XP superior to 2000??? Are you kidding? It may boot up 15 seconds faster but that is about the only advantage. The interface is slower - takes more resources to run. Put one computer on 2000 and then on XP and there will be a slowdown in the GUI (not noticable, but 2000 is less graphics-intensive). Security Features? LOL. If you are running that "firewall" in XP I suggest you get a real one. Any other security features are pretty weak also. Hardware compability? Bah. Ever since XP came out hardware has come with NTx drivers, so this is a non issue. IMO 2k > fischer price windows any day of the week. I will most likely be upgrading to Vista or perhaps 2003 Server once I am forced to (WMP 11, IE7 (I use mozilla and moz firefox but some sites just bitch if you don't use IE - and IE6 might not cut it in half a year). XP though, imo, is a complete bloated joke of an OS.
I thought it was common knowledge that Win Vista was based on Windows Server 2003.eeyrjmr said:I was under the impression that Windows:Vista was being written from the ground up
On Aug. 27, 2004, ... The day before in Microsoft's auditorium, Mr. Allchin had announced to hundreds of Windows engineers that they would "reset" Longhorn using a clean base of code that had been developed for a version of Windows on corporate server computers.
And considering XP runs faster on newer machines, what does that say about your argument? As usual, the argument degrades down below the important facts. If performance is what you are concerned about, you need to look at drivers. They have been optimixed for XP, since XP is the standard platform right now.Steel Chicken said:thats just memory. try running both of those OS's (2K + XP with classic look) on an progressively older machines. which one will continue to run on older hardware, and which one will choke first?
pbj75 said:I agree that is in the article, but it does not actually say Windows Server 2003.
Yes the main starting point for work on Longhorn was the Server 2003 SP1
codebase whcih in trun was a follow on from the code base of XP SP2.
Obviously we are now moving away from this as work continues on the product.
Pretty much all versions of Windows have started the next version
development from the previous one. The effort involved in rewriting from
scratch and tens of millions of lines of OS code would be gargantuan.
Regards,
Mike
Mike Brannigan [Microsoft]
pxc said:I thought it was common knowledge that Win Vista was based on Windows Server 2003.
pxc said:link
You can find hundreds of other links that say the same thing. Like I said, it's common knowledge.
Of course. Why do you think flaws that affect any OS generally affect the family? This is new to you? I know your into linux a bit, but do you run any MS OSes?eeyrjmr said:So Vista based on 2k3, which was based on XP which was based on 2k, which was a major overhall of NT
So in reality there is a hell of alot of code re-use from Windows2000
Moving from XP to 2000 for your average home user/game rig machine...there isn't a lot to offer that is much different that would justify the cost of scrapping everything and getting XP.
Phoenix86 said:Up until recently I would have agreed with you, and since no one wants to delve into my questions about 2K, I'll answer them. AOE3, a MS game, does not run on 2K, a supported MS OS.
I don't know what the technical issue is, or if there's a workaround or not, but I think it's a moot point.
MS is not producing software on the OSes they support. This is the begining of a trend...
The Other reason I was asking is because this isnt the first Time I have come across code-reuse. about 4months ago I was writing a work report and in WORD I click to open a docu BUT accidently chose an Excel file (running OfficeXP at the time) Now what I was presented with was a Windows3.1 dialog box (the bevelled buttons gave it away) asking abt data inport, that screemed out that there was some legacy code in windows (in office for the fn calls as well as in Windows system dialog code)
S1nF1xx said:Talk about knit picking.
Nobody other than you cares about "used code". I couldn't care less if the code from Notepad.exe came from Windows 3.1 or was freshly written. The fact is that it doesn't matter as long as the program works.
You're fueling a senseless debate with the most trivial of issues. Did it ruin your day that the money you spent on Office XP didn't include new code for a warning dialog box? Please..
Vista is a new OS. Not a service pack nor an expansion for XP. It will be same type of update XP was from 2000. There are large chunks of code taken directly from XP. I'm willing to bet the code for Notepad and Solitare didn't change either.But it's not like 98 where you're actually running Windows on top of DOS. It's a new OS.
yes, it is. Microsoft has a term for it. They call it 'pushing the market.' It's also the same reason that it's easier to register domains and active directory clients in post-SP2 WinXP boxes than it is with current Win2k boxes. Microsoft is no dummy. They know that if they make an OS completely compatible and completely stable, then no one will upgrade. So, they make them as stable as they can since they sit in the hot seat if a major security flaw causes a government agency problems or the like. however, they can choose to make things 'incompatible' since there is no real brick-n-mortar real-world tangible way for 90% of end users to cry foul.eeyrjmr said:Isn't this a sign of MS "bullying" ppl into upgrading
Generally, I'd agree with you. As a professional engineer, I can vouch for the value of design/code re-use. It definitely allows a team to progressively improve a product over time.S1nF1xx said:Nobody other than you cares about "used code". I couldn't care less if the code from Notepad.exe came from Windows 3.1 or was freshly written. The fact is that it doesn't matter as long as the program works.
It's like a mini-debate with yourself.svet-am said:Generally, I'd agree with you. As a professional engineer, I can vouch for the value of design/code re-use. It definitely allows a team to progressively improve a product over time.
However, seeing Win3.xx dialog boxes is scary for entirely different reasons. If they didn't catch that (which they should've given that it's as simple as altering which MFC classes are being used), then what *else* didn't they catch.
When that old code was written, current dangers didn't exist. MS got into trouble with this a lot in the late 1990's/early 2000's because people were executing buffer overflows and the like on legacy code in order to gain access to the now-protected kernal space.
I'm not saying that MS should re-write the OS every time out, but they should do a more thorough audit each time out.
No, there's no disagreement at all. I say that, in the abstract, code re-use is good. However, Microsoft's *implementation* of code reuse is poor.Phoenix86 said:It's like a mini-debate with yourself.
First you say it's good, then you say it's bad. Finally, you end up with it's good, but should be reviewed more.![]()
ever since the Apple Intel switch was announced, there have been rumblings in the various circles around WINE/Cedega that it wouldn't be too hard to extend WINE/Cedega to run on Intel under MacOS X.laxmiddi44 said:i don't know if you guys have realized but all the features they are adding to vista, mac osx already has......maybe except for a few. I mean i know you can't play games and all etc....but the switch to intel might eventually solve that over the years...
svet-am said:ever since the Apple Intel switch was announced, there have been rumblings in the various circles around WINE/Cedega that it wouldn't be too hard to extend WINE/Cedega to run on Intel under MacOS X.
I'm not a WINE/Cedega developer, but if they can get it running on MacTel (running well, that is), then we might see the tables turn.
Maybe. MacOS has been a viable (viable in the sense that games will run properly) platform for years, but few games get ported. If MacOS (since it's a BSD) could get support via WINE and/or native games, they MAYBE more developers will port. But, I think that Apple will remain the Nintendo of the home PC world.eeyrjmr said:Now I didn't think of that. IF Cedega sales increase (sinceOSX ~ BSD ??) and recent games run good, then the dev for Cedega will increase and they may finally hand back code to WINE
That is a minor thing, BUT if game dev's actually see LINUX/BSD as a viable gaming platform then more native games will start to appear
I have no idea why it has that requirement, I'm with you, there's not likely a technical reason. However the installer demanded it.Nasty_Savage said:True enough. Obviously I do not have that one game, nor am I running Win2k anymore, but its just one anomoly and maybe a few others down the road. Its based on the same kernal and Direct X so unless there is some specific XP doo dad I am not aware of, I don't see why it would not work. Hardley a deal breaker for the Win XP/2k game rig debate...unless that was the only reason you would build a rig for that game
kumquat said:Sure, but they aren't exactly taking that middle ground.
There is very, very little that's new about Vista besides the shell.
