Vista won't show Logon Screen?
shadow1988
Today I was cleaning and decided to dust my PC out with compressed air. When I hooked everything back up and booted I got this problem. It shows the little loading bar at first and then shows a black screen. It never gives me the chance to enter my password. Any one have any clues about what could be the problem.
Vista Ultimate
9800gtx+ Sli
c2d e6600 @ 3.4
4gb RAM
580w Hiper type R
250w juice box dedicated to GPUs
Open it back up, re-seat your RAM and any add-in cards. Also double check all your power and data cables for a loose connection. May want to leave it open, power it up and mack sure all your cooling fans are working. Sounds like something got moved, disconnected and or knocked loose.
Done this enough times to know it's a loose something, in my case it's usually RAM.
