vista wont load
01WS6
im sorry in advance idk witch topic this fits but, i just bot a new mother board and i was going to turn my pc on and, and the vista load bar loads but then it just re-starts and tries again, it just keeps doing that
idk if its the HD failing or something
but i tried to open my cd drive to insert the Vista CD but it wont open :/
any help?
dont put the vista disc in a cd drve. its a dvd. get a paper clip and straighten it out. find the tiny hole on the front of your dvd drive (not the led!) push the straightened paper clip into the hole and this will cause the tray to eject.
unplug any extra drives, opticals, usb stuff except what you need to boot up, ie, boot drive, keyboard, mouse. see if it boots into windows. if not, press f8 while you are booting and see if it will boot into safe mode. if not, take out all ram except 1 stick and try to boot. then report back.
mhy cd drive wont open when i put the paper clip into that small whole :/
