I can't install Vista 32-bit Home Premium OEM on my P5B Deluxe.
I'm using all new hardware. Not going for RAID. Flashed to BIOS 1101 before install. Formatted the drive during setup, Vista extracts and configures then reboots. Then the system hangs at a black screen then says:
Windows failed to start. A recent hardware or software problem might have caused this problem.
Then it reboots and does the same thing over again.
Just as a test I installed XP and it worked fine. How can I install Vista?
Specs:
Asus P5B Deluxe
E6600
Raptor 150GB
Corsair 2GB RAM
Specs:
Asus P5B Deluxe
E6600
Raptor 150GB
Corsair 2GB RAM
