vista wireless issues
resolve
Having odd problems with vista and my wireless router(s).
My laptop (running vista 64bit home) can connect to both my wireless routers only if no Windows XP machine has connected to it since the router was turned on. It connects just fine after a restart of the router, works perfectly normal and everything. As soon as one of my XP machines connects to the router though, the vista laptop's connection fails, and it just gets stuck at connecting.
Is this to do with IPv6? drivers? any help?
That's weird... To me it seems like the routers problem.
Have you tried updating the router's firmware?
^^^ + 1
What is your router? Sounds like the router is the issue, but make sure you have updated firmware on router, as well as drivers for Vista and XP machines.
