Vista Upgrade...
BNut96
I've never had much luck with any of the Windows upgrade packages. Seemed to be plagued with bugs etc. I was just wondering if purchasing the WinXP to Vista Home upgrade is worth it or should I just pick up the full version?
I was running XP pro..... I bought the Home Prem upgrade. Since you can not upgrade from XP pro to Home Prem, you are forced to do a clean install.
basicly doing a clean install takes all your old docs , programs, ect... and puts them in a dir called Windows.old.
and then it will do a fresh install of the Vista Home Prem.
I just went through it lastnight with my install.
gl
dan
