Ok, I'm confused....
I am looking at getting Vista Home Premium Upgrade but I have a couple of questions.
I have running XP Pro now and when you look on Microsoft's web site it says I need to do a "clean install" for Vista. So...With an upgrade version of Vista is their idea of a "clean" install just overwriting the old XP files or is it a true "clean" install which wipes the drive clean?
I know about the workaround to get a cleaner install but this one threw me for a loop.
Also now that it's been out a bit, has anyone tried the workaround and does it work? Mainly at letting you repartition and reformat the drive?
Thanks!
Thanks!
