Do you have an example of what window gives you 3 prompts????
Again- logging on as "admin" is a bad thing. That is EXACTLY why Microsoft put UAC there, because people still do it.
The Linux community has always understood this- very very few people log in as root on Linux, yet it's common on Windows. Only solution would be to make Administrator a limited account itself, hence UAC.
Yes, I know all thatThe actual admin account itself is disabled. Any account you create as an administrator account, has two tokens. One of a standard user, and one of an admin. For every purpose that it can, it will use the standard user token, when it can't it will prompt you with UAC to use the admin token.
I guess you're going to have to elaborate... If you're talking auto-elevate what the heck good security is that??? You're back to XP.Personally I leave UAC on so that other users that I create still get the UAC prompts, and then I just made it elevate without prompting for my admin account through secpol.msc
And you're less susceptible to zero-day attacks because.............If you're asking what I do, I say turn it off.
If you're asking what I think other people should do (a typical computer user), I say leave it on.
Thank you, I was going to say the same thingIn other words, bullshit. There is nothing - no single action you can possibly come up with - in Vista that requires 3 UAC prompts to appear one after another, period.
I have to visit the washroom CONSTANTLY when I go out drinking. The English language is meant to be interpreted, not taken literally.When someone says "UAC pops up CONSTANTLY" it's obvious they're full of shit and just typing to be typing. Anyone that uses Vista for 10 mins knows UAC doesn't constantly pop up, that's just silly and totally inaccurate. There's a reason for it popping up, and while it might seem like it's constant, it's far from it.
More people complain about Vista because of UAC than most any other reason, so it gets old fast, especially when their complaints are typically unfounded and just full of bullshit whining, and that's not a good reason either.
I don't understand your question. Can you rephrase it?
I really couldn't care less what other people are saying. I'm quite content having my own opinion and letting other people have theirs (correct or otherwise).
Yet you felt compelled to some degree to click that Reply button and post your own opinion, right? That's what my question was prompted by... and no, it wasn't a UAC prompt either.
Since when? Maybe I dont read enough things other than Engineering books, instruction books and rulebooks (I used to collect miniatures), but I've always taken the english language literally before trying to interpret it (ie. assume literal speaking before assuming I need to interpret it).
Since forever. You'd be surprised how much of the English language is non-literal. Most rhetorical devices are interpretive.
Even statements like "I have to go to bathroom" contain elements meant to be interpreted. We take that statement to mean "I really want to go to the bathroom", or we presume there to be an implicit qualifier on the statement like "or else I will piss myself". (yes more washroom stuff )
I don't find that stance all that shocking coming from an engineer. Often they have a comparatively harder time integrating themselves into society because they do tend to only take literal interpretations of things. And I'm an engineer myself... often I've misinterpreted people for this reason.
Wow this is OT.
I agree 100%.When someone says they are annoyed by it and that they do find it obtrusive, it's ridiculous for someone else to come and tell them that they're wrong, because clearly they do feel that way.
Can you explain how?if you're going to have automatic elevation it is at least a little better than XP, since most programs will be running with limited privileges and that makes using them as attack vectors more difficult.
Did I say I was? No. I simply said that if it's me, I turn it off. I didn't say I'm against it, I just don't want it activated for my personal use.
Off. I do nothing on that particular computer but browse and use office so there's no sensitive information to be had if anything happened.
I have always had it on, but it isbeginning to annoy. They really need to update it with an "always allow" list option.
Is there a way to allow certain programs to bypass UAC(like Rivatuner and CPU-Z)?
Yes, you can create a task in the Task Scheduler utility and tell set it to "run with highest Privileges. You can set it up to run at startup or create a shortcut to the task that runs this command:
schtasks.exe /run /tn "task name"
It will allow you to run that program without a UAC prompt.
I know what I am doing
That's my first solution.Or just don't use second rate software which generates unnecessary UAC prompts!
I see, makes sense. I still don't agree with disabling it though.It is basically the same thing as back to XP. I leave it on, so that for other users on my machine, people like my gf or friends, still have the benefit of UAC enabled and they can't screw as much up because they are standard users. Myself, however, I know what I am doing and can live without the prompts, so I make it automatically elevate because I am in the Administrators group.
And this right here is why I don't agree with disabling UAC... 100% QFT.Do you trust that none of your programs have security flaws that might be exploited?
i'm fairly certain, that exact phrase is what puts the UAC advocates into a fury...I turn it off. I know what I'm doing and don't need some app questioning me.
Sorry Catweazle, i fixed it just for you =)i'm fairly certain, that exact phrase is what puts MOST OF the UAC advocates into a fury...
I used to leave it off but was convinced to turn it back on.
