verylostindeed
- Dec 27, 2004
So, I just made the switch to Vista from XP. Here is my setup:
C2D E4300 @ 3ghz
ASUS P5k motherboard
2x1gb gskill DDR2 ram
GeForce 8800 GTS
and so on.
I'd happily been running @ 335mhz on the FSB for quite a while on XP; something in the neighborhood of 8 months or so.
When I switched to Vista and downloaded CPU-Z, though, I've noticed something strange: it appears to alternate the reading back and forth between 3 ghz and 2 ghz sporadically; it appears to be reading the multiplier as changing between "9," the default, and "6."
I'm not sure what's going on here. The ASUS overclocking utility (which I never use) confirms the cpu-z reading. I downloaded the latest bios, etc., for motherboard and it still reports the same thing.
I never noticed this on XP. . . .
Any thoughts? Thanks.
EDIT: I'm wondering if for some reason one core is only running at the 6 multiplier? Not sure how to fix that, if so -- no bios settings to that effect. I've already tried the power options to see if that is the source of the throttling.
C2D E4300 @ 3ghz
GeForce 8800 GTS
and so on.
