Some programs will no longer launch from the Recently Used Applications list in Vista. If I go to All Programs and find the program, it will launch, and if I browse to the program folder and click the .exe file, it will launch..but when I click on certain programs in the Recently used applications list, nothing happens at all.
Apparently I'm not alone:
http://www.vistax64.com/vista-general/120404-start-menu-wont-launch-applications.html
http://timewarptechnologies.com/node/93
http://forums.windowsvistamagazine.com/forums/thread/8050.aspx
The solution is supposed to be to disable certain Shell extensions, but I've already tried that and it didn't work. I disabled every single one but the problem remains.
I've recently installed WinRAR and Unlocker (http://ccollomb.free.fr/unlocker/) but uninstalled both and there are no traces left of them.
