DeftonesXP
- Feb 7, 2006
The problem is the following : once every few usb connects, vista crashes hard... no blue screen, no auto-reboot, everything is frozen and I have to use the reset button.
Waiting does not resolve the problem
Googling for this problem wasn't a success at all. This started happening only after the installation of SP1. Vista has been running flawlessly for 2 months before SP1
Here's the config :
Asrock 939Dual-SATA2
Opteron 165 @ 2.6 ghz
Geforce 8800gt
Vista 32bit business edition
Some might tell me that the 939Dual-SATA2 is not Vista compatible, but after some research I found that its identical brother, the 939Dual-VSTA is vista ready, and their only difference is the integrated sound chip (which I don't use anyway).
Thanks in advance
Here's the config :
Geforce 8800gt
Thanks in advance
