vista slow download rate Why???Help
x58noob
I am running a Gigabyte x58 extreme,Intel i7 920,evga 295,6gb memory,1000w ps,
I have been downloading wow patchs all day the download rate is 65kb to 80kb. its slow as hell is there a fix for this???Help please
I ve been reading alot of different opinions I disabled auto tuning already Someone also said to download this file but i dont know if its good or not WinVista_6104_NIC_8139-20070620.zip The network adapter is Realtek RTL 81680/8111d family pci gigabyte ethernet nic
any help???
WoW patches are notoriously slow.
try something like itunes from apple. or a common speed test. please note that even if you can download 800kb/s. not everyone can upload 800kb/s. 2 way street I suppose.
There are links to direct download patches. I forget where. there is also a tool which converts blizzards auto downloaders into a .torrent file which in a real torrent program yields much better results..
also. there's a way to increase your internet speeds. microsoft "reserves" 20% of your bandwidth in default domain settings. it's a bug. but you need to set it to 0. can sometimes increase your speeds.
Is the down loader saying that you are behind a firewall? The Blizzard patcher does that and it slows you down. Make sure it has an exception in your Windows Firewall and make sure the ports are opened in your router firewall. You can usually do something like add application, name it, then specify the ports to open, then apply that to the specific PC.
