D
Deleted member 143938
Guest
Can I use an iPod to boost my memory in Vista, effectively having something around 31gb of RAM? That sounds crazy, that's why I'm asking. It'd be so cool if it would work that way
I still don't understand. Would plugging my iPod in for the speedboots... provide any kind of a speed boost or anything that would be used in my favor?QFT
Readyboost takes advantage of the fact that flash memory has very fast access times (especially on random, small reads) compared to a hard drive which can take a few milliseconds to start transfering data to your system bus, RAM, video card, etc.
However, once that transfer starts, your hard drive is probably significantly faster (depending on the speed of your flash memory).
Readyboost keeps a copy of certain parts of your system page file so that the Operating system can more quickly page to/from disk.
Personally, I notice a big difference when I play a game, and then resume my general Windows desktop use - the Readyboost drive helps repopulate your system RAM from the page file which is a much bigger deal in Vista than it was in XP - since in Vista, your system RAM stays populated with applications/code that you frequently access.
I hope my run-on sentences weren't too horrendous!
First of all, Readyboost requires FLASH memory
I've used itI'm unsure if the option being available during "Auto-Play" directly means the device is usable. I've tested a few USB drives that come up with this in "Auto-Play" but never actually create a pagefile on the device, nor can they pass the WinSAT tests for ReadyBoost.
Another advantage of iRiver... you can defragment the darn thing.Besides, you would want Readyboost cache on a device/drive that's not fragmented to hell and back..
Ditto, Ditto, Ditto. RB sucks, IMO, and more RAM is the only way to (still) go.If you need a substantial speed boost for your games, OP, you need to buy more system memory.
OK, so since iPod is a HDD, it won't help. But what if I get a cheap 1GB flash drive, would that provide a speed boost? I don't quite understand how it works, does adding lets say a 1GB flash drive to act with speedboost 'trick' it into thinking I have 2GB of RAM on my computer?
I have 1GB real RAM right now
If you use ReadyBoost because you think it speeds things up (I don't think it helps at all, but whatever), good for you.
But there is ZERO reason to go out and buy something for ReadyBoost. If you are going out to buy something- buy real RAM. ReadyBoost is no replacement for REAL RAM.
[snip..] another gig of my ram would be 120 dollars
[snip..] quite a bit more expensive than a
[snip..]1GB flashdrive that costs 20 max.
[snip..] free speed boost (or so I thought)
I never claimed it is, that's how I thought it works, and if not, it's obvious according to the description that there's some kind of a speed boost involved. Now I don't know where you buy your RAM, but another gig of my ram would be 120 dollars, quite a bit more expensive than a 1GB flashdrive that costs 20 max. If I had money, I'd buy RAM, but my question wasn't about RAM, it was about a pretty much free speed boost (or so I thought)
If you aren't already using a device for caching, and the new device is between 256MB and 32GB in size, has a transfer rate of 2.5MB/s or higher for random 4KB reads, and has a transfer rate of 1.75MB/s or higher for random 512KB writes, then ReadyBoost will ask if you'd like to dedicate up to 4GB of the storage for disk caching. (Although ReadyBoost can use NTFS, it limits the maximum cache size to 4GB to accommodate FAT32 limitations.)
