Vista Problems
Joseph42
Help!!!!
I have an Asus P5E3 Deluxe/Wi-Fi motherboard with a Penryn QX9650 CPU. Running Vista Home Premium. I have a Raid 0 on two WD hard drives. I keep experiencing errors and lockups when trying to install the Asus AI suite software from the disk that came with the motherboard. I have also downloaded the latest Bios and version of the AI suite software from the Asus web site and installed all available Vista updates. Still having problems with installation.
Can anyone help?
Run memtest, see if any errors pop up. When it installs, does it throw up any error codes, or just lock-up? Does your computer freeze when installing any other software, or just that app? I'd also make sure that the app is vista compatible, I've had the problem installing previous versions of Asus apps. I know you said you dl'd the newest version, but it never hurts to double check. I'm not sure if the hd's are the problem. I know WD has tools you can dl to check for any errors, but I'm not sure if they work on RAID's or not. May want to check on that. If not, at least run windows disk check, see if it turns anything up.
If none of that works, your computer is possessed. ;)
