Okay, I'll keep this brief.
Vista 64-bit. Everything up to date. Everything works perfectly for hours, and hours. Then all of a sudden, my internet will partially stop working.
Now, it's odd because it doesn't disconnect me from anything. It seems to no longer open any sockets. For instance, if I'm browsing the [H] forums, they'll work fine so long as I keep browsing. MSN won't disconnect me. IRC keeps working.
Hell, it happened the other day while I was playing WoW and everything worked fine.
However, if I try to access a new webpage, sign on to MSN, log on to another IRC server, even try to ping somewhere, it fails untill I restart.
Resetting the router, disabling/renabling the connection, zip. A reboot always fixes it, and it will work for hours on end again, before it randomly breaks once more.
Any ideas, chaps?
EDIT: Upon further investigation it appears that ICS is the cause of it - However, I still wouldn't mind knowing if anyone has a solution, cheers!
Any ideas, chaps?
