I have googled this one and have been struggling with it for the past two weeks.
I bought an LG R500 notebook that came preloaded with Vista Home Premium. I need to use Autodesk Inventor 2008 on it. In order to install and use the Content Center Libraries it must run and pass the "ADMS System Check". In the system check everything passes except for "Checking for port 80 availability". It says "Another webserver may be using port 80." It tells you to run netstat -ano to find which process is using port 80. The problem is I'm not seeing port 80 being used at all.
Click here for the netstat report.
Apparently Skype can cause this problem however I haven't installed Skype. I think it is related to a Windows update or some other software I have installed because I reinstalled Vista and then installed Inventor with the Content Center Libraries and it worked fine. I thought I got it but then the next day when I went to run it the Content Center didn't work and the ADMS system check failed because of port 80 when I tried to reinstall. I think the only changes overnight were a bunch of Windows updates.
I don't know what to do now. Any suggestions? I can't go with Windows XP because I can't find all the drivers I need for XP.
Thanks
Thanks
