Is there any difference between vista OEM home premium and regular vista home premium????
Because the OEM costs wayy less.
Thanks
I read some where that OEM can only have one online activation, and 5 call in activations.
The risk of losing your activation code if you change your hardware. There's no telling what might happen in the future.
At Anand's a guy posted he switched his memory from 2gb to 4gb and had to reactivate and it didn't work. Then he had to call microsoft activation center and spent a couple of hours on the phone.
So anyway, 64 bit vista has all the new security features, whereas the 32 bit doesn't have them.... So before buying think on that...
Uhmmm... No.
One of the primary benefits of using an x64-based version of Windows Vista is that these versions provide dramatically improved security features when compared to their 32-bit counterparts. Most dramatically, the Windows Vista x64 versions include a new secret security feature that will virtually eliminate remote system attacks for the first time on the Windows platform. This feature, previously undisclosed, ensures that system files load at random (1 in 256) memory offsets at every system boot, compared to previous Windows versions where system files always loaded to the same offset memory location. Because of this change, most (approximately 99 percent) remote attacks will simply fail on x64-based Vista versions.
Working in tandem with the No Execute (NX) technologies in modern x64 microprocessors from both AMD and Intel, Windows Vista x64 versions, like XP x64, also provide support for hardware-backed Data Execution Protection (DEP), which helps to prevent the buffer overflows that are commonly used in electronic attacks. (32-bit Vista versions utilize a less effective, software-based version of DEP.) Another unique x64 feature, PatchGuard, prevents malicious software from patching the Windows Vista kernel. PatchGuard, Microsoft says, works by preventing kernel-mode drivers from extending or replacing other kernel services and preventing third-party software from patching any part of the kernel.
Additionally, Windows Vista x64 versions require that all drivers be digitally signed by the developer. If you've ever installed a driver in Windows XP, you'll likely be familiar with the unsigned driver dialog, which offers a "Continue Anyway" option when a setup application attempts to load an unsigned driver . In the x64 versions of Windows Vista, this will not be possible. Microsoft says that it is requiring signed drivers so that it can ensure that drivers are of the highest possible quality; poorly-written drivers are, today, still the leading causes of blue screens and other system instability issues.
When taken together, these features ensure that the x64 versions of Windows Vista will be both the most secure and reliable versions of Windows ever created. Likewise, they will be more secure and reliable than the 32-bit Vista versions.
I usually build one PC and wait for it to either go dead
Unless you plan on buying a new mobo...just buy the OEM. It saves you 200$.
Exactly! Whats the posibility of this? Not highly like it. Im cool with my OEM.Even if you do buy a new mobo, assumin you only buy one, you could buy a second OEM copy and still come out even.
