This almost always happens if you install a third party text editor.
My guess is the .txt extension isn't associated anymore...
This may be the quickest way to fix it- go here and run the TXT fix... http://www.dougknox.com/xp/file_assoc.htm Extract to your desktop, run it... see if it is fixes.
