hey all... i have a netgear wireless router that i use just as a wired router(got it at best buy for cheaper then wired router ) i have the radio turned off... Ive had it for about a year now... and just the other day i was transferring a 700mb file through the router from an xp machine to my main box w/ vista and i got an icon on my vista saying a network wire was disconnected... i checked the router and it looked frozen... so i reset it... unplugged it.... left it off for 24 hours... nothing worked... did it just go bad ? or did vista break it because Ive heard other people having similar problems...
thanks!
thanks!
