Edit: Looks like I found the big problem, later in the thread.
We just started using Vista Business on our new machines at work. I needed to migrate some information from another computer, so I placed it on a SATA drive, attached it and copied it over. It is 15 files composing 20GB. However, as I tried to copy them over, I immediately received an error message of "Out of Memory". If I hit "Try Again", the error would pop back up. If I skip the file and go to the next, I'd get the same error on the next file.
I check Task Manager and I see:
System:
Handles: 1293496
Right now, I'm OUT of memory, literally! I've closed down every foreground app except Firefox and explorer, and I have 2 MB free (I had to kill some services just to start Sysinternals procexp).
I had to check with my other XP boxes to form a frame of reference, they're all using between 15K and 20K handles.
This may be associated with another weird Vista error I'm having.
I have a bunch of movie files from my DVR (recorded shows) that I watch. Once I finish watching most, I delete them to save space. 90% of the time, if I watch a video, then Shift-Delete it, it will immediately pop back into the directory. The file is deleted, but explorer.exe is keeping a locking handle on the file that I have to manually track down and kill to get rid of the file in the directory. Though, if I do a regular Delete, it usually deletes it fine.
System:
Handles: 1293496
