You didnt misread the subject. My experience with Vista is much faster than with XP, same computer, same outrageous amount of software titles than I will hardly ever use. Vista:
a) Loads faster
b) Loads programs faster
c) Allows for faster user experience when using programs and browsing files
It is important to say that I didnt notice difference while it was clean, it is only when I loaded all the software, then it became clear that Vista is faster. Mind you, I noticed faster experience before defragmenting for the first time, after defragmenting for the first time it is blazing fast.
I run a lot of crap in background too, MSN Messenger, Skype, honestech TVR, DAEMON tools, Remote control, Symantect AV, SOUNDMAN.exe, Aero, Sidebar full of gadgets, big resolution, voice recognition.
Recovery from errors is easier too, I dont even have to reboot.
Things bad about Vista:
a) Requires beefy video card, $90 buys 512 MB card that does the job done
b) Does not support some of the hardware, such as game/midi ports, Sound Blaster Live! Value.
c) Windows Media Center does not work with cheap sabernet tuner.
d) Vegas and all other Sony software does not work with Vista, probably due to the fact that Microsoft has its own solutions in place, I have hard time believing Sony was lazy enough not to make those work.
e) Adobe Acrobat 8 does not work with Vista, installer keeps restarting all the time.
Thats all folks. There was more fuzz back when XP came out. Every guru was recommending to stick with 2000. It wasnt until I met the real guru who told me XP can do things that 2000 wouldnt, when it comes to recovery, then I upgraded, and loved it.
With Vista, I went to it a month after it came out, and I already love it. I use it for software development. By the way, Vista is a lot like XP/2003. VISTA IS A LOT LIKE XP/2003. Debate all you want, VISTA IS A LOT LIKE XP and 2003.
I got in serious using speech recognition, speech recognition as apple is that export!
"I am typing this using speech recognition. Speech recognition does not work in Vista!"
SO, SHOULD YOU GET VISTA? ONLY IF IT DOES NOT COST YOU MONEY! You should also consider buying a computer other than crappy Dell, as Dell is known for crap and Vista requires top of the line. (Mine was build by me in 01, and it still is tops of the line.) Just a .02 cents there coming from a guy who actually completed his certs and does IT administration for a living.
P.S. Vista is a lot like XP and 2003 Server. It uses some Windows 3.1 code too, such as message box code.
