Vista installs fine until reboot
ZMAN Z28
I am trying to dual boot Vist with XP Pro. Vista installs without any problems. When I get to the welcome screen and start using Vista, everything works as expected, not great, but I get to use the operating system. When I reboot the system, my computer only has the option to boot to XP. There is no option in the boot ini file that recognizes Vista was ever installed. The partition which I installed Vista to has it in there. I have tried formatting the partition about 3 or 4 times and every time I install Vista, I get the same results (Vista works untill I reboot and then I can't boot to it)
Has anyone else experienced this, or any ideas how to fix it?
Thanks, ZMAN
I had a similar problem. I had XP on one hard drive & Vista on another. I was not able to get a boot menu to display. I had to go into my bios & change the hard drive priority setting. I believe you can add info to the XP boot.ini to boot into Vista.
I just did a Google search and found the following utility for Vista. It's called EasyBCD. It may help you.
