Alright. I'm trying to install my vista ultimate x64 I just got. I install it. After 30 minutes or so i've entered my key and did the actual install portion of it. Once installed it makes your restart, once restarted I take the CD out so it boots from my HD. When it goes to boot from my HD it says:
"WIndows could not start because the following file is missing or corrupt: <Windows root>\system32\ntoskrnl.exe"
So I boot with the CD in and I go to repair mode. It scans and then it says "Windows cannot repair the problem" or something along those lines. I've tried this 3 times now!!!!!!
I consider myself a above average in the computer field and if I can't figure out how to install it It makes me wonder how regular joes do it.
Please tell me i'm missing some small step that causes this error.
Thanks.
Thanks.
