Aug 24, 2008 #1 T theTIK Gawd Joined Jul 3, 2003 Messages 757 Is there any way to remove the highlighted box around the desktop icons when you roll the mouse of them in Vista?
Aug 24, 2008 #2 bigdogchris Fully [H] Joined Feb 19, 2008 Messages 18,708 Yes, but if you're using Aero, you won't like what it does to the rest of your GUI. I promise you.
Aug 24, 2008 #4 bigdogchris Fully [H] Joined Feb 19, 2008 Messages 18,708 Down8 said: Way to link/explain the answer! Click to expand... OK, follow these steps. Right click in my computer, go to properties. Click Advanced system settings. Under performance, click settings. Under Visual Effects tab, scroll all the way down and un check the very last box. Apply it. See that I was right and you wasted your time. Come back here and post "bigdogchris, you were right."
Aug 24, 2008 #5 J jratzo Limp Gawd Joined Feb 3, 2007 Messages 266 I tried it for the hell of it... Wow that was terrible
