VISTA how much memory needed for dual display?
faiser
All, I'm currently waiting for my new Dell desktop with 7900GS 256MB :p
I use dual 19" CRT at the moment but plan to upgrade to dual 20.1" OR single 24".
My question; will the 256MB pull off 2x 1600x1200 in Vista Aero glass?
I was also wondering if one can choose aero glass for one monitor, and classic desktop for the other. Is this possbile? And if not, even when using seperate video adaptors?
Thanks a lot!
I doubt you'll have any problems, I've run rc1 on 3 monitors, 2 19s powered off a x600 and a 24 running off of a x800gto2. Haven't tried it with an nVidia setup, but I imagine you shouldn't have any problems.
Thanks for that
Do you know if Vista allows for selecting aero on one card and classic desktop on another? I have a spare old pci card that is definately not aero capable and I was wondering if I can put it to use for a 3rd display without sacrifying aero on the others..
I highly doubt you will be able to choose aero on one card and not for another. If you did that you would have to be running 2 (or more) separate desktops and that would be almost like having 2 users using their own desktops at the same time. So my educated guess would say no
No, Aero is either on or off globally. Even for applications Vista will turn of Aero to run incompatible apps. Then turn it back on when that program terminates. If a video card (and thus it's driver) isn't compatible with Aero, Vista will just turn it all off.
