Sir_Poop_Alot
- Aug 2, 2008
I got this problem with a fresh re-installation of Windows Vista. Everything is setup with the correct drivers and all the application that I use on a regular basis. Every time I try to "Remove Hardware Safely" from the sys tray my system goes on a seisure... the circle cursor is spinning. My monitor flashes.. i cannot get to task manager. My dual screen seems to swapped places. This continue until i do a hard reboot since I can't access anything else. I suspect it's ATI's radeon drivers. I'm using ver 8.11 and experience this problem. Prior, I was using 8.8 and 8.9 and did not experience this error. Has anyone else experience this perplexing problem? Let me know if you know what's going on. TIA!
