Vista DVD maker - AVI burning troubles
MrHood22
It seems like windows DVD maker or w/e it's called in vista doesn't let me burn AVI dvd's.
When I try to add a movie it says "file is either missing or corrupt" or something along those lines.
Any ideas?
Thanks.
You might try re-encoding the video with Windows Movie Maker. Anything it spits out should work fine in Windows DVD Maker, and if you use one of the higher quality output options there shouldn't be any noticeable degradation.
How do I re encode it with WMM?
I opened it in WMM, and then saved it, and tried to add it to the DVD maker and it said "Cannot add because this file only contains Audio files. If you want to add video files go to WMM."
Import the clip, drag it to the storyboard/timeline at the bottom of the screen, then go to File-> Publish Movie. Publish to "my computer" and use the default encoding option. Make sure you can play the new video in Windows Media Player.
It sounds like you might be dealing with a codec issue.
Yes the AVI plays in WMP.
It's an xVid I think.
I have the DivX Codecs installed
Hmm,
Download and install the KLite Mega Codec Pack from here. Use all the default install settings.
Try re-encoding with WMM again. You might even be able to burn directly with the DVD maker using those codecs.
I've never had trouble playing/burning anything with that codec package.
k, installed it.
I still get the same issue though.
I put it on the timeline view, drag it down, and it changes to story line view and it shows up as audio/music then it prompts me about "audio clips can only be added in story line view so it has switched to story line view" or something like that.
Dang, where did you get this file? :eek: ;)
The only other free solution I can think of is to try Super:
http://www.erightsoft.com/S6Kg1.html
Scroll down to where it says "Download SUPER © setup file."
You'll have to play around with the options, but hopefully that will work for you.
