WickedWeasel
- Jul 13, 2004
WinXP is installed on drive C, and a ghost image is made
then install Vista on drive D, and make a ghost image
both WinXP and Vista are working fine.
now
install ghost image onto drive C for WinXP
does vista still work? is there an easy fix to make it work? or do i have to make a new ghost image of C AFTER vista is installed?
if after installing the ghost image onto C above works for WinXP, will it also still work when i boot into Vista ?
Another way of asking this same question is, does the installation of Vista as a dual boot in drive D alter WinXP in drive C?
now
