maxiedaniels
- May 25, 2005
Okay, so last night I finally installed Vista. I put it on my second hard drive (XP is on my first). I was planning on setting up a dual-boot menu on startup, but I didn't get that far before Vista killed itself.
I plugged in my phone via usb (mass-storage device), and all was well. Vista recognized it. I was transferring things over to the phone, and then all of a sudden: 'Windows Sync Manager has crashed". Then it said something about trying to repair the issue. Then again, it crashes. And then: "Windows Sidebar has crashed". Again, it tried to repair it, and the repair window crashes.
So I take out my phone, and then I just started surfing sites on the internet (this site actually). Out of nowhere, "Windows Explorer crashed". So I'm stuck with no start menu or anything. Then it says that Windows needs to repair. After a while, it says it can't repair, and to try a System Restore. It does that, restarts, and says that I need to boot from the Vista cd and select 'Repair Computer'. I do that, and when it gets to the screen, it says that corruption is detected on my hard drive (secondary one with Vista) and that I need to run disk repair. I click okay, and it goes to disk repair. Scans my entire drive, and it says everything is fine. It goes back to the original screen, and once again says my drive is corrupt.
Okay, so I've officially lost faith in Microsoft. I want to attribute my issue to user error, but I barely did anything with the system. It only took around 20 minutes to completely fail on me.
Now, first, does anyone know what could have gone wrong? Is this some known issue?
Secondly, and more importantly, how can I boot back into XP? I was going to boot from the XP install disc and go into repair console and do the fixboot and fixmbr commands (I think those are right?), but I wanted to check with people on here first.
Thanks!
Thanks!
