Ok, so my computer is throwing a fit, and it's finally so bad that I have no choice but to do something about it.
Specs:
AMD X2 4200+ 2.2Ghz
ASUS A8N-SLI Premium
2GB ram
NVIDIA GeForce 280 GTX
Antec PowerTrio 600w PSU
The problem:
My computer used to be mostly stable. I say mostly, because every now and then it wouldn't detect all of my hard drives at boot and would need to be powered down and cold booted to detect them. I had an iffy drive at that point so I figured it was causing a hang at post and making the drive detection go funny. That drive finally died and is being used as a doorstop in my livingroom.
About a year or so ago, I got Vista home premium x64... installed it, and all was good in the world - until a month later when my OS partition got corrupted. None of my data was touched, JUST drivers and other vista crud. Fine, whatever, format->reinstall (thinking at this point it was due to one of the power outages we had)
This ended up happening a couple more times, and always at the worst possible moment. AKA, paper due, day off to play video games, etc.. FINALLY I solved the problem by getting rid of the IDE drive I still had in the system. Switching over to SATA gave me 4 or 5 months of crash-free bliss.
Until a week ago. In the last week I've installed vista 3 times, and each time a few hours into it started showing signs of driver corruption (dlls "close unexpectedly", control panel items won't open, etc..) Also, the disappearing drive problem has reappeared at boot.
So I switched and decided to try XP.. which works, and doesn't get driver corruption. However, I get Machine Check Exceptions every couple hours. If I enable my wireless network card I get them every time I access the internet.
I've run memtest overnight with no errors, tested my PSU both at idle and load and there was little variance, I've had different combinations of hard drives in this machine and vista has been installed and corrupted on each one.
Oh and the real kicker? Linux shows NO sign of ANY problem. I used it for the last month of school last quarter because I couldn't take any risks with not being able to use my PC...
I'm thinking there's something wrong with the chipset on the motherboard. Thats why the hard drives disappear at boot.. also could be the reason the wireless card causes MCE's?
Any advice on this one is appreciated... I won the GTX in a contest, so I kinda want to upgrade anyways, anyone recommend a decent $300-400 CPU/MB/RAM combo to match the GTX 280? Or any thoughts on the problem in general?
Specs:
AMD X2 4200+ 2.2Ghz
2GB ram
The problem:
